gbopp wrote:
Lwiddis wrote:
Read the contract twice and slowly. And are preexisting problems covered?
And, what are the exclusions..
Basically, if you damage it yourself, it's not covered. Now, how do they determine what YOU have damaged and what is a result of inferior craftsmanship?
You hitch up your trailer, you take off down the road. You end up on a very bad gravel road. You hit a massive hole, hard, and the trailer tire hits hard. Now you have a bent rim. Who's at fault here? You the owner for being in such a situation in the first place, or "they" the manufacturer because the rim did not hold up under "normal" conditions.  What's considered "normal". The warranty companies will do their best to determine the failure was a result of your negligence due to abuse on the camper, or negligence due to lack of standard-customary maintenance. That's the "exclusion" where you loose.
They can blame a failed refrigerator on you because you drove over bouncy roads and all the bouncing killed the refrigerator... your fault.
They can blame a leaky roof on your failure to take the camper in for service once a year for an inspection and now the calking is cracked causing a leak. It's your fault you didn't pay attention to it.
They can blame the radio going out because you connected to shore power and got a surge and it blew the radio. Not their fault ... yours.
It can go on and on.
