restlesswind
Sep 29, 2013Explorer
rhagfo wrote:
I always extend the outer leg 3" to 4" before dropping then inner legs to pads. This is with the rig level side to side, Once inner legs dropped I shim so they are both the same distance to the top of the pad, then extend to take the load. This gives the adjustment to level front to rear.
I also do the shim routine.After dropping the legs and not shimming
I found that the trailer would sometimes end up off level side to side.(After I had leveled using lego blocks)
Now after checking an shimming if needed,no more side to side
level problems
About Fifth Wheel Group
