deleted-2
Sep 29, 2013Explorer II
Don & Carolyn wrote:
What is meant by "marked the max up and 3 inches down on the legs with a marker pen?"
I marked the front jack legs maximum up because if the stops were encountered the in-line fuse would blow.
The reason I marked the legs 3 inches before the mechanical maximum extension was because:
That's about the best place to stop the legs before un-pinning to let the feet drop onto my 4x6 blocks.
I found that when the jacks are electrically extended further than usual with the drop feet as short as possible the trailer rocks and rolls a tiny bit less.
I normally try to park in spots that are level as possible front to rear.
Doesn't always happen however.
Every trip is an adventure in leveling.
About Fifth Wheel Group
