biljo99
Oct 02, 2013Explorer
All the stability of the fifth wheel is on the outside part of the leg.
You should let the outside leg down to at least the halfway point or more before you pull the pin and let the inner leg drop. This also gives you plenty of room for adjustment up or down as needed to level out the trailer. You should also notice a whole lot less rocking. The motors do go slow but I think you will appreciate the rewards of your patience.
About Fifth Wheel Group
