jimmy16x's avatar
jimmy16x
Exterior rear wall feels spongy
I've been considering buying a five or six year old smaller fifth wheel and looked at two nice ones yesterday that had a spongy feel on the outside rear wall. One was a 2013 Wildcat and the other was a 2015 Cougar. Both were 30 footers with a large rear window and below the window the fiberglass exterior would flex in and out when I pushed on it. Both sides of the window and above it and the rest of the walls felt firm and looked good. They were at two different dealers and the salesman at both told me that was fairly common on these models with large rear windows. Anyone had any experience with this that can give me some advice? Thanks
  • Delam or not, it needs an independent inspection anyway. Stealers all lie to sell. Common knowledge.
  • Back walls are just hung there's no glueing. If you want the spongy gone its not hard to take the back off and glue it
  • Thanks for the replies. I'm going to check more units that are similar and see if most of them seem the same. No signs of leaks or water damage anywhere and it really feels like the outside fiberglass panel is just attached around the window and the outside edges which causes it to flex in and out a little near the middle.
  • WOW! lots of bad advice...IF it's a hung wall...ie. Wildcat that is normal. Geeze :(
  • Our former rear kitchen Copper Canyon had "flimsy" walls in the back - it was hung insulation, not foam laminated to the fiberglass wall. Our Grand Design Reflection is laminated foam all the way around. There is no wave showing on the rear wall like the Copper Canyon.
  • I can tell you my 2016 Keystone Hideout's back wall feels very different than the side walls. I noticed it the first time I looked at it when it was new on the dealer's lot. There always could be damage but if the whole thing feels consistently soft across the back it's likely just the way it's built.
