I have a 2016 F-350 SRW longbed and a 37' fifth wheel and on concrete interstate highways the ride is terrible. Does anyone else have this problem and what have you done to alleviate it. The ride is g...
Know your rear axle load. Use the tire/weight inflation chart for your tires add 5psi to what the chart lists. Install Bilstein 4600 shocks. If you are not satisfied add air bags and run about 25-30psi when hitched.
