turner66
Sep 15, 2013Explorer
Owning a 2012 F-450, I can tell what I know first hand:
- The 800 ft.lb torque, 6.7L motor in the 4.30 geared 450 chassis tows like a freight train
- In 2012, from the factory, they only came with 17in wheels and 4.30 rear gears.
- The wide frontend on the 450 is a noticebale difference over the narrow trucks (improved stability)
- The disc brakes are 1 inch bigger in the front and 2 inches bigger in the rear. No problem stopping alot of weight.
- Ratings on anything but a 13,300 GVWR truck wasn't enough for my 18K 5er. That puts GCWR at 31,300 which is over the F-350 rating of 30,000.
- I haven't had the need, nor would I want to use this truck as an offroading mud machine. I don't think it would do well, nor would any heavy dually with LR E tires. I have a Toyota FJ with Nitto mud tires for that.
Personally, I'm convinced the 450 is the right truck for the job. But, I'm also sure a 350 could do it, although not technically within all the rating limits (1300lb over GCWR).
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
