MFL
Oct 21, 2016Nomad II
OP....You are not giving much info, as to bracket type (sliding?). Has the installer used this set up in other aluminum bed trucks, to know if it will work?
Are you referring to Reese standard rail mounts? Is the other Andersen bracket you mention, a rail mounted Andersen hitch?
With a little more info, or picture, you may get more, and hopefully better responses. We all know there are FW hitches installed in some F150s.
Jerry
Jerry
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
