Sport45
Oct 21, 2016Explorer II
rhagfo wrote:Bipeflier wrote:
Steel brackets directly against the aluminum WILL cause corrosion issues down the road.
X2
Yep Raw AL steel bolts and rails, I would drill the holes then have spray in bed liner applied. then place some type of thin rubber between the Frame brackets and bottom of bed.
Every vehicle I own has aluminum wheels pulled up tightly against steel hubs using steel studs and nuts. Not one of them is showing any corrosion issues???
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
