LIKE2BUILD
Oct 25, 2016Explorer
Timeking wrote:
I am getting conflicting answers. The dealer says it won't work, and the place that sells and installs the Reese-type bracket says it will work. So what is the answer? Anyone have one of these trucks with a 5th wheel?
The other post on this forum is about an Anderson bracket.....
Does Ford not offer a 5th wheel prep kit for the F150? What about aftermarket hitches, do they have a puck system for the F150? I have the factory prep kit in my RAM2500 and LOVE it. There is absolutely nothing in the bed except the trim rings around the pucks. I know Ford has a similar system for the F250 so maybe there's an option for your F150.
If there is no puck system, why not look at using a B&W Turnover Ball and Slider Companion Hitch and be done with it. This will give you a clean bed with no permanent rails and the corrosion issue is a total non-factor.
KJ
About Fifth Wheel Group
