- 3oaksExplorer
goducks10 wrote:
Good question!
Whats the new 2017 SD doing for the aluminum bed issue?
Perhaps it is only a perceived issue by Ford bashers? :@ - goducks10ExplorerWhats the new 2017 SD doing for the aluminum bed issue?
- FarmerjonExplorer
Bipeflier wrote:
Steel brackets directly against the aluminum WILL cause corrosion issues down the road.
Good point, after the finish is worn away. - rhagfoExplorer III
X2
Yep Raw AL steel bolts and rails, I would drill the holes then have spray in bed liner applied. then place some type of thin rubber between the Frame brackets and bottom of bed. - BipeflierExplorerSteel brackets directly against the aluminum WILL cause corrosion issues down the road.
- FarmerjonExplorer
B.O. Plenty wrote:
There is no place in the truck where the hitch is just bolted to the bed. It will have steel brackets under it if that's what you are referring to.
B.O.
X2!
maybe the 1/2 ton is the issue? - B_O__PlentyExplorer IIThere is no place in the truck where the hitch is just bolted to the bed. It will have steel brackets under it if that's what you are referring to.
B.O. - MFLNomad IIOP....You are not giving much info, as to bracket type (sliding?). Has the installer used this set up in other aluminum bed trucks, to know if it will work?
Are you referring to Reese standard rail mounts? Is the other Andersen bracket you mention, a rail mounted Andersen hitch?
With a little more info, or picture, you may get more, and hopefully better responses. We all know there are FW hitches installed in some F150s.
Jerry - csamayfield55xExplorerPersonally, I wouldn't put a paper clip in one of those aluminium grocery getters!! Again, that is just my personal opinion with a bit of research I have seen. If the dealer says don't do it then I would for sure look for a different path!! Dealers are notorious for telling people they can do way over what the truck really can
Chris - donn0128Explorer IIWhat size fiver?
If dealer says no, i guess you have your answer.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
