Beaker's avatar
Beaker
Fifth Airborne Sidewinder problem
Just installed topic title by my lonesome without forklift, etc.
Anyone wanting to know how pm me.
But that's not why I am posting. Ran into a small, actually large problem when done.
The distance between bedrails and fifth wheel is 3.5 inches higher than with my old one which had already made the front nose high. Axles have already been flipped. Although there are holes left in the wings to adjust the pinbox they can't be used because the pivot of pinbox would be above the wings and destroy them.
The hitch is already at its lowest setting.
Cutting the wings would solve the problem but I'm sure that's a no-no.
Any thoughts before uninstalling and returning?
  • I know this is an old post but I have exactly the same issue with my trailer being nose high. I'd like to cut the wings off and give myself 3-4 inches extra room to lower the pinbox. Structurally it looks sound . Has anyone cut the wings to solve this problem?
    I replaced the slider base with regular base and lowered it 1.5". Had the local trailer(not rv)guy raise the rear 2" by using lower holes and welding 2" extensions for the equalizers.
    I would also like to know the answer to your question, not that it would help me now.
  • RoyB's avatar
    RoyB
    Explorer III
    I was expecting something about SPECIAL FORCS
    Not one of these...
    sample photos from GOOGLE images
    Roy Ken
  • I have the 19k version. The problem I ran into was the top of the "air bag housing" would contact the underside of the trailer if I went up higher in the mounting holes. I had to modify my hitch head to lower it to compensate for the additional height of the sidewinder.
  • Beaker wrote:
    Some people have trimmed the outer portion of the brackets that hold the pin box, but that is because they can hit the sides of the pickup bed on tight turns and they only cut the horizontal portion, not the vertical part.
    The "outer portion of the brackets that hold the pin box" are called the wings. If I could cut 3" off horizontally, that would allow the turret and pinbox to install 3" higher solving my problem.
    But I need "someone in the know" to tell me that it is structually sound to do it.
    I can't imagine that removing 3" would be OK unless new wings were welded on higher. But call Reese, they must have had this issue already. The Sidewinder/Revolution is available as a factory option on some brands and models, so this shouldn't be a surprise issue.
  • Some people have trimmed the outer portion of the brackets that hold the pin box, but that is because they can hit the sides of the pickup bed on tight turns and they only cut the horizontal portion, not the vertical part.
  • Can you lower the hitch in the truck bed? When I needed to lower my hitch, I had to modify the hitch crossmember at the bottom in order to use the highest holes since the bottom contacted part of the slider mechanism.
    Some people have trimmed the outer portion of the brackets that hold the pin box, but that is because they can hit the sides of the pickup bed on tight turns and they only cut the horizontal portion, not the vertical part. Not sure how much you would have to cut off to clear the Sidewinder.
  • You may have to put a lift kit on the 5er. A trailer shop can weld a spacer to jack it up some. May need to take the sidewinder back off :(.
