tvfrfireman's avatar
tvfrfireman
Fifth whee hitch problems and need advice
I need some ideas from some of you mechanically minded. We bought a larger, heavier fifth wheel and so I am selling our Companion that works with the under bed B&W. We have gone to a Hensley TS3 and in order to make it work, I purchased a Curt X 5 adapter. I also have a bed rug and needed to cut the fabric and fold it out of the way so the curt adapter can sit on the metal bed and allow the B&W to be lock the curt adapter in place. I dropped the Curt adapter into the square hole to use it as a template to cut the carpet. Now the carpet is cut but I am unable to lift the one hundred pound curt adapter back out of the hole as it seems stuck. I don't own a engine hoist and though someone here might have a solution. Thanks for any help in this matter. David
  • Crown a 2x6 up across your bed rails, then use a ratchet strap to pull it up.
  • get a rod and a bottle jack go under the truck put the rod through the b& w and jack the plate up out of the hitch
