md4142 wrote:
Thank you all for your comments. The converter/charger is a Paralax LLC
brand. At this point, I need to clean up the acid/water mess, bite the bullet and purchase a new battery. Thinking about a AGM battery replacement; they are expensive but will not have the electrolyte water level maintenance to worry about.. Recomendations for a reliable 12 V deep cycle battery?
Thanks again for your input.
There are several good AGM batteries out there, I like Optima, but there are those who do not like them! Remember one thing, if the battery advertises "cold cranking amps", or CCA it is not a true deep cycle battery! If you do any dry camping, look for two 6 volt AGM batteries hooked up in series which should give you the extra amps for dry camping!
