goducks10
Aug 20, 2014Explorer
You'll find that the "1/2 ton" jargon will mostly refer to the weight of the 5'er. Most are in the 6500-8000lb dry brochure weight, which falls within most 1/2 ton truck tow ratings. What they don't tell you is that, the 6500-8000lbs will be 7500-9000lbs+ when loaded. That makes the pin @20% around 1500-1800lbs. Then add 200+lbs for the 5th hitch as most need a slider and your at 1700-2000lbs on the rear axle. Over all but the highest rated 1/2 tons. They aren't really lying but just stretching the truth a bit since some 1/2 tons can tow them.
About Fifth Wheel Group
