kopy_kat
Aug 20, 2014Explorer
Even though I have a F350...my Flagstaff 8528IKWS is dry rated at 7900 lbs. and fully loaded sits at around 9500 lbs...which might fit within your Toyota's ratings--you'll have to check your GVWR rate to be sure.
As for the short bed, the Flagstaff has the Reese Revolution pin box--I can easily back it at 90 degrees and cut cookies in a parking lot...
so no expensive slider needed with the Revolution.
Larry
Larry
About Fifth Wheel Group
