jus2shy
Aug 31, 2014Explorer
Water-Bug wrote:
Nobody has mentioned it but 20" wheels, that are the current rage on 1/2 pickups, knock the heck out of most truck's towing capabilities. Just a warning to would be 1/2 ton PU 5er towers.
EDIT. When you are approaching the limits of a TVs capabilities, the little things can put you over the edge.
The wheels don't hurt much of anything. With my F-150, my OEM "P" rated tires on my OEM 20" rims had the same amount of capacity as the OEM 18" wheel/tire combo that was a load range "D" tire. Wheels really don't do much of anything, what matters is what is spec'd out for the overall tire/wheel combo. Just to drive home the point, for Ford's strongest SRW F-350 towing/hauling package, you are going to have 275/65R20 tires that sport about 3,800 lbs of load capacity per tire. Yes, that is a 20" wheel.
About Fifth Wheel Group
