Atwood 85 Series Error Codes
Internal Circuit Board Failure...........Steady on, no flashing
Limit switch/Airflow problems............1 flash with 3-second pause
Flame Sense Fault........................2 flashes with 3-second pause
Ignition Lockout Fault...................3 flashes with 3-second pause
*Low gas pressure
Set pressure to a minimum of 11 ? W.C. with all appliances running.
Replace regulator if not obtainable.
*Exhaust blocked
Clean exhaust.
*Combustion air wheel loose
Reposition wheel and tighten.
*Electrodes out of adjustment
Adjust electrode----1/8" gap between spark electrode & ground rod.
*Electrode defective
Replace electrode.
*Circuit Board defective
Clean plug contacts. If still defective, replace. (Check on board tester when possible).
*Flame sensor wire between electrode and circuit board defective
Replace wire.
*Air leakage at gaskets
Replace gasket.
*Defective heat exchanger
Replace heat exchanger.
