crcr
Jun 01, 2013Explorer
hmknightnc wrote:plake1 wrote:
ty what does wd mean and a tt is hooked different. I an concerned that the truck may be light on the front when I get a bigger load on it right now its okay empty but I want to go to a bigger 5th wheel and again am concerned for safety when I get a bigger one
Get the hitch installed correctly. You're gonna need all the cushion you can get towing a FW with a 1/2 ton truck. Not sure what FW you have now but the max payload I can find on the Ford website for the supercab, ecoboost, and 3.73 rear end is 2,000#. Now subtract 200# for the hitch and just guess at another 300# for passengers and gear in the truck only leaves you with 1,500# for pin wieght. That equates to about a 7,500# GVWR FW, pretty small is your maximum capability with a FW
OP didn't mention the configuration of his Supercab Ecoboost, but IF perchance he has the MaxTow plus the HD options, he may have a payload of over 2400 lbs, depending on the options on the truck.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
