Cummins12V98
Jun 06, 2013Explorer III
bishkoff wrote:Cummins12V98 wrote:bishkoff wrote:Cummins12V98 wrote:45Ricochet wrote:
If I put 16-20% of my pin weight on the front axle it would put me well above my FAWR :E IIRC 40 lbs of my pin weight is added to the front axle.
Interesting, if I had 16% of my 4,500# pin weight on my front axle that would mean 720#. That would put me at 5,900# on front axle still 270# under axle rating. I am full forward with the B&W and only add 100# to my front axle.
I think someone's info is wrong!
If you are using the truck in your profile, your Front GAWR 5500LBS
Sorry you are correct! I was looking at my tire ratings.
Thanks for the correction!
I run a 2005 Dodge that only has 5200# Front GAWR, I was surprised at how heavy the front axles are on these trucks when they are empty.
It's that BAD AZZ CUMMINS that sits up front!
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
