smoke20's avatar
smoke20
fifth wheel hitch newb ???
i'm usually posting on the truck camper group so i'm not sure if this is the right group to post this in or not but here goes,
i recently got an 07 f350 drw the previous owner had either a 5th wheel or goose neck mount on the bed. they have some holes already drilled through the bed but they are a little dfferent from what i have seen before. i want to put 5th wheel rails in my truck so i can pull my dads 5'er
there are six holes in the bed, four look to be lined up properly and two are jus off to the side of the of what look like "right" holes. it looks like some one drilled two holes in the wrong spot then drilled four holes in the correct location. hope that makes sense.
anyway my dad has a 03 f250 and his 5th wheel rails have four bolts per rail, two on each end which makes for a total of eight holes in the bed
i want to use the existing holes in the bed of my truck so i dont have to drill more holes in the bed. so my question is is there a manufactuer that makes rails that mount with only two bolts per rail? any help would be appreciated
heres some pics of the hole locations
right
left
