Cummins12V98
Mar 23, 2016Explorer III
I am sure I will get comments from this but I know many others do the same.
With a B&W there is no reason to do a pull test unless a person wants to. I am sure other hitches are in the same boat. With the RBW I had prior I ALWAYS did a pull test.
All that is required is VISUALLY confirm the following. Visually confirming is a test!
1. confirm the hitch plate and kingpin plate are touching.
2. confirm the 1" thick jaws are closed around the kingpin.
3. confirm the handle is closed and pinned or LOCKED as I prefer.
If you confirmed visually all the above there is NO REASON to do a pull test.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
