cummins2014
Nov 14, 2017Explorer
Cummins12V98 wrote:Durb wrote:
I can't understand all the objections to bed rails but then my truck is not a gravel hauler. You can get a Bed Mat by BedRug and cut out openings for your rails. The mat thickness is the same as the bed rail height and when loading stuff it slides right over the bed rails. It is also very easy on the knees. Just an option.
If you used your truck as a truck you would understand!
I think he understood perfectly, and explained to the readers a solution, might try reading his reply again.
Had bed rails for years with no issues using the truck as a truck, not sure I understand your comment. What hauling sand ,gravel, rocks , no big deal, so I am at a loss about your comment. :h
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
