OutdoorPhotogra's avatar
Aug 12, 2017
Fifth wheel hitch questions
Greetings All,
About to move into the world of fifth wheels. Have never towed or hooked up a 5er so this is new territory. I've researched hitches from old threads and think I want to go with B&W Companion. I'm open to your arguments for something else.
Heart of my question is does it hurt to buy a hitch rated far above your current 5er's weight?
My 5er will be 8,500 lb GVWR and towing with F-250 long bed, 6.2 gas. B&W Companion is way more than I need. Patriot would be find for weight. I'm considering Companion because:
1. I want/need a flat bed with hitch out to carry kayak, etc. Seems Patriot is only a rail system.
2. I would like to transfer the hitch to a another set-up if/when I upgrade 5-10 years down the road.
Can you buy too much hitch?
What is the life expectancy of a hitch?
Can you move it to another TV without issues?
  • I don't have Ford's factory 5th wheel prep. I could buy the Ford kit and the Ford B&W but even though I will likely stay Ford, I think I'll buy B&W's version rather than OEM to give flexibility in the future.
  • you can never buy to much hitch. as long as a truck has the B&w ball system it will fit any
