IBcarguy's avatar
IBcarguy
Leveling 5th wheel question
I've got a new Jayco 5th wheel and I'm using a Andersen Ultimate hitch. The trailer is just about level however the edge of the pin box is very close to the bed rail when in a tight turn into a driveway or when the trailer is crooked to the truck. I don't want to raise the upper ball one hole and loose my level rig. The pin box has several mounting holes and I think I can adjust the pinbox to set closer to the bottom of the trailer. Then I think I can raise the ball one hole, giving the pinbox more clearance to the bed rail without changing the height of the front of the trailer. It sounds a little confusing but my son came up with this and after explaining it to me like I was a six year old, it made sense. Question is does changing the position (up/down) of the pin box in the mounting bracket effect anything? I don't think it will change anything but I'm no expert.
