dieseltruckdriver wrote:
laknox wrote:
Mine is an '04 model, so they may have changed the jaw action over the years. As I said, I did try it with the handle unpinned and pulled forward, but it would NOT unlatch. I've actually done it a couple times, the first time being =very= early in my ownership. Neither time did it unlatch.
Lyle
My Companion with a turnover is over 6 years old, and it only needs to be pinned open if you have all the pressure of the hitch pin against the front of the hitch. This only happens if you are unloading while pointing downhill, such as where I park at home. Also, if you take the pin out as soon as you unhook there is no problem pinning the handle open. I have to pin my hitch open every time I unhook here at home. Your older unit might work differently, but what you described won't happen with the newer ones. My best friend just put a puck system in his new TV, and the basics are the same as mine.
Also, everyone should do a walk around after hooking up. If that is done, there is almost no way that anything can go wrong with a B&W hitch. It would be looked at several times, when checking your lights, hitch, tires, making sure the chock blocks are removed, windows closed etc. Not doing a walk around after hooking up is irresponsible.
Your post does make me wonder if and/or how they may have changed them.
Edited to add: I do not mean this as an attack or doubting your experience laknox, but just to let newer inexperienced folks know the proper way to hook up. When I reread my post, it looked like I was going after you and I am not. Sorry about that.
Having grown up on a farm, I developed the habit of shifting to N whenever unhitching =anything=, very early on. There was no pressure on my jaws before I pulled the handle to unlatch and wheels were firmly chocked. (shrug)
Lyle
