motorcycle_jack
May 24, 2013Explorer II
When I jack up my MS, I use the hydraulic lifts to raise the side I need up high enough then put jack stands under the frame and lower unto them. The lifts are rated at 17K each and are much easier to use than a bottle jack. I've change all four tires three times this way due to bad tire stems. Finally found Sure Valves and that cured the problem. In the last year and a half haven't jacked it up once!
About Fifth Wheel Group
