5thwheeleroldma's avatar
Mar 22, 2014
Jack Points on 5th Wheel?
Does anyone really jack up their wheels by the frame? I tried that once and had so many blocks stacked up under the jack, plus you have to have two jacks, that it was really shaky and dangerous.
I guess they are afraid you will damage the axle tube, but that is what I have ended up doing. I put a bottle jack close to where the U-bolt attaches to the axle and jack there. I know it is not recommended, but I think you will eventually kill yourself trying to jack up the frame.
I suspect the axle people are just covering their donkeys. Any brilliant ideas out there? I used to be an engineer; why not just manufacture the axle with a flat plate (for jack) welded on close to the U-bolt location on each side of the axle?
