Puddles
Mar 22, 2014Explorer
donn0128 wrote:
To change a tire you always place a Jack under the spring perch. To lift the entire trailer you need several Jack stands on each side.
Pretty hard to jack under the spring perch, if it's on top of the axle... I cut a piece of 3" pipe long enough to fit between the u bolts... Then cut a 1& 1/4 piece of pipe about 1 inch long... split the 3" pc and welded the smaller one in the center, on the outside of the 3 incher.... this little device will sit on top of a bottle jack and won't slip off... The half circle won't slip off the axle or bend it... Wish I knew how to post a pic..
About Fifth Wheel Group
