taybrynn
Jul 14, 2014Explorer
Yes. I found out this can happen if you over retract the landing gear. You may need to connect the rod Nd a new pin and manually crank it back down a bit. Then put a mark on your gear that shows you not to retract above that line.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
