laknox
Aug 15, 2016Nomad
prk7 wrote:
Are there any drawbacks of adding a ten inch pin box extension to a montana 3791?
If you have a "standard" pin box, where the pin is literally under the front of the FW, Montana likely offered an extended pin box as an option. That being said, Montanas that are a few years old did have some frame issues, and almost all seemed to have factory-installed extended pin boxes.
ON EDIT: One of the reasons that I want to stay as close to 30' as I can, is to avoid having to make sharp turns like this. (That, and to avoid having to buy another truck to handle a bigger FW.) FWIW, the '02 D'max in my sig will NOT hit my very square-front Komfort at full lock, R or L; ALL will hit in reverse. A slider just gives you more room before you DO hit. :-)
Lyle
About Fifth Wheel Group
