donn0128
Oct 04, 2015Explorer II
3/8-16 threded rod, measure to length. 3/8-16 hex nuts, qty 2. 3/8-16 wing nut. Drill a 3/8 diameter hole in the tank mounting plate. Thread on one hex nut push rod through the drilled hole and secure with second hex nut. For the tank top brace a piece of 1-1/2 inch angle will do the trick. Drill a hole in the middle, and cut a couple of notches on the opposite edge to slip into the tank handle. Tighten with the wind nut. If you want,send me a pm with your email address, will be glad to send you a picture.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 23, 2026
