TucsonJim's avatar
TucsonJim
Explorer II
Oct 04, 2015
Fifth Wheel Propane Tank Mounting Straps Broken
On my 18 month old FW, the top propane strap has broken, and the bottom one has a hair line crack. This looks like metal fatigue. So I have two questions:
1. Does anyone know where I can purchase replacement straps? My search was unsuccessful.
2. Have any of you FW owners found a better way to secure the tanks? I'd appreciate your suggestions.
Thanks,
Jim
  • I received the picture from Donn0128, and it is for a double tank mount with the threaded rod coming up between the tanks. That is typical for what you'd find mounted on the hitch of a TT. These are single 30# tanks in FW cabinets, so you still need to have access to get the tank in and out without hardware getting in the way.
  • Helimech - Thanks much - that sure looks like it. I'll go take a measurement to be sure. In the mean time, I'm very interested in modifying the mounting as the folks mention above. These straps are a very cheap way of doing things.
  • Hello Jim,
    Is this what you are looking for?
    http://www.makariosrv.com/single-propane-cylinder-strap-90032/
  • 3/8-16 threded rod, measure to length. 3/8-16 hex nuts, qty 2. 3/8-16 wing nut. Drill a 3/8 diameter hole in the tank mounting plate. Thread on one hex nut push rod through the drilled hole and secure with second hex nut. For the tank top brace a piece of 1-1/2 inch angle will do the trick. Drill a hole in the middle, and cut a couple of notches on the opposite edge to slip into the tank handle. Tighten with the wind nut. If you want,send me a pm with your email address, will be glad to send you a picture.
  • Donn0128 or Shadows4. Any chance one of you could post a photo so I could clone it? Thanks much.
  • Mine is as Don describes. Maybe you could use some nylon straps instead? Good luck.
  • Mine uses a clamp, large threaded rod and wing nut to hold them in place. 10 years with no problems. Maybe its time to fix it correctly.
