- ShepherdExplorerHe must be enjoying the weather.:h
- NC_HaulerExplorer
Depay4305 wrote:
Have 2008 Cameo what is rim width and psi rating. will it take 110 psi
What happened to the OP? One question about 3 days ago and no follow up? - NC_HaulerExplorer
john&bet wrote:
NC Hauler wrote:
Sorry, they do not have G's on it. I was very surprised to see the label on them when I had new tires put on last year. I currently have Firestone transforce LT's. The Montana has a gvw of 12,100#. Believe it or not, but it came with made in USA LT's back in '05. From what I read here they do not put those type tires on these 5er's anymore.john&bet wrote:
My fiver has steel wheels and it is on a label on the inside of the rim, meaning you have to dismount the tire to find it. I noticed it when I had new tires put on last year. They are 110psi rated on 5080# axles. Go figure.
Guess I completely over looked the above...sorry about that....so your axles are rated at 5080# and with a 110psi rating, might guess you have "G" rated tires on the 5er...same as I have on mine and my axles are rated at 7,000#.... 6.5" wide rims for the GY G614's rated to 110 psi...just as an example.
Pretty good deal on OEM tires you had on your 5er.....My bad though, I got you confused with the OP, sorry about that.....but sounds like back in 05', a manufacturer actually went "above and beyond" and put decent tires on a unit:) - john_betExplorer II
Guess I completely over looked the above...sorry about that....so your axles are rated at 5080# and with a 110psi rating, might guess you have "G" rated tires on the 5er...same as I have on mine and my axles are rated at 7,000#.... 6.5" wide rims for the GY G614's rated to 110 psi...just as an example. - NC_HaulerExplorer
Might be easier to figure out if we know the GVW of your 5er....axle ratings would work to. IF it's a "typically heavy" Cameo, could be you have 7,000# axles with "G" rated tires which take 110psi..but I'm speculating on all the above...thus the reason I asked about the GVW on your 5er...should be a placard somewhere telling you tire size and weight range recommended as well as 5er's GVW...
What tires are on your 5er now? - john_betExplorer IIMy fiver has steel wheels and it is on a label on the inside of the rim, meaning you have to dismount the tire to find it. I noticed it when I had new tires put on last year. They are 110psi rated on 5080# axles. Go figure.
- 1492ModeratorMoved from Forum Technical Support
- DevocamperExplorerlook for the stamping on the inside of the rim
- fla-gypsyExplorerThe wheel ratings are usually found on the backside of the rim. Some will only have a weight rating others will also indicate a psi rating. If you only have a weight rating post it here along with wheel size and the current tire weight/psi ratings and a psi rating for the wheel can be extrapolated from it.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
