Ron3rd
Dec 12, 2017Explorer III
Max PSI rating on Trailer Wheels?
My trailer's Alloy wheels are 15 x 6, 5-lug.  The load rating stamped on them is 2150 lbs.  It came with 225-75-15, load range C tires, which run 50 psi. These tires are are marginal IMO for the trailer which has a gross weight of about 8600 lbs.
When I replace the tires, I'd like to go with load range D tires that run at 70 psi. How do I know from the specs on the wheel if they can handle the higher psi?
