Old-Biscuit
Oct 15, 2016Explorer III
Searching_Ut wrote:
It's a ball hitch. Gooseneck style as far as local DMV is concerned. As for trusting Andersen, after their lack of response regarding the damage their hitch adapter caused to my fifth wheel, I not only no longer have faith in the hitch I now don't trust the company. Good luck should something go wrong and you end up in court. Using "Andersen said" probably won't cut it. Check with your local authorities and get an answer from those that will be the decision makers.
Aren't you the one that posted pictures of the pin box bent/damaged from using the Andersen Hitch.
Bottom on pin box where king pin is attached all bent up/distorted!!
I have always said....right tool for the job
Gooseneck trailer....ball hitch
5th wheel trailer....5th wheel hitch
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
