Sport45
Oct 17, 2016Explorer II
Dayle1 wrote:
I believe there is an underlying technical reason for chains on ball mounts and not on king pins. There is only a single size king pin, 2 inch and any hitch should work with and pin, SAFELY. But there are multiple ball sizes and someone can carelessly drop a 2-1/4 coupler over a 1-7/8 ball and the mistake is not visible, then a tail heavy load, a bump and trouble, hence chains. Has nothing to do with which type can haul more and even Andersen won't warranty stupid.
I think (but could be wrong) the safety chain requirement is due more to how they latch. If you fail to latch a 5th wheel they'll typically drop when you pull away. If you fail to latch a ball hitch you will probably get on the road just fine but the unlatched trailer could bounce off the ball at any time and at any speed.
So I have no issues with using chains for ball type hitches whether they're on the bumper, in the bed, or elevated as in the Andersen or Pullrite designs.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
