cummins2014
Dec 24, 2015Explorer
RangerEZ wrote:Kevin O. wrote:
After reading OMEXTREME post about him blowing out his back window and denting the cab while using the Andersen. I have changed my mind. If I had a long bed I would give the Andersen a try but I'm not going to take any chances.
Kevin
Couple things to consider. The Andersen may still be a good solution.
#1) He did not have the Andersen set to its rearmost setting.
#2) He has a newer Ram. They have different clearance issues than you are likely to have in your truck.
I thought I would have some clearance issues when I went from a Ford Superduty to a Ram Megacab, because of the shorter bed, but no problems. My king pin is 2" forward of the rear axle, same setup as the Ford.
An Andersen would give me even more clearance in the rear position .
About Fifth Wheel Group
