SkiSmuggs
Feb 15, 2016Explorer
Twomed wrote:
Google Reese Sidewinder... set once and forget it. It does have weight limitations.
I used a Sidewinder for 4 seasons. I wouldn't say "set and forget" as that will lead to disaster. The four turret bolts loosen with use and have to be torqued to 45 ft/lbs on a regular basis. I had two of them shear, probably aggravated by a near tip-over when two fiver wheels dropped off the trail in a natural campground. The shearing occurred a few thousand miles later and I discovered it when I checked the torque. I am not advising against the Sidewinder at all, just saying you can't forget it. You can forget about ever hitting the rear of your cab though.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
