Kevin_O_'s avatar
Kevin_O_
Fifth wheel slider hitch options
My truck is a 2001 F350 crewcab with a 6'9" bed. I thought my mind was made up on a Pullrite superslide, Now after talking to a few people I'm thinking it might be to heavy? I'm already half boinic with 2 fake hips, fake knee, and back problems. So I'm going to need a hitch that is a little easier to take in and out when I'm not using it. I also have been told the Pullrite can be tough to hook up if your not completely level?
So now I'm leaning towards a manual slider hitch which I'm guessing is much lighter in weight and might be easier to hook and unhook? I also would like to know how often you guys actually use the manual slider? Any suggestions will be appreciated!
Kevin
  • Unless you are concerned with payload weight once a hitch weighs much more than say 100lbs what difference does it make? IOW's, if a hitch weighs 150 or 250 I'm not lugging either by hand in and out of the bed!
    I went with the SuperGlide and love it.
  • Google Reese Sidewinder... set once and forget it. It does have weight limitations.
  • All sliders are on the heavy side with the auto sliders being the heaviest.
    As others have mentioned consider the Andersen. Very light and it gives an extra 5-6" of clearance vs a non-slider hitch and is likely all you need.
  • MFL wrote:
    Kevin, you may not need a sliding hitch. I have not needed one with last two FWs, and two 6' 9" Fords.
    I have no experience with the Andersen Ultimate hitch, but they are very light weight, and many on this forum, seem to like them.
    Jerry
    Kevin,
    I tow a fifth wheel with a 6' 5" bed (GMC 2500HD crew cab) and don't need a slider. I use the Andersen Ultimate (standard rail mount) and the hitch only weighs 48# if I want to take it out of the bed. The system is also very quiet without chucking or clanging noises.
    Rob
    Kevin
    I've used one for 9 years. Heavy - Yes. It breaks down a bit, but the main box part of the hitch is heavy. I can muscle it around, but I can see why you'd be concerned. I have thought about attaching a pulley to the garage truss to make it easier.
    I have never had troubles hooking up when not level, not sure what they could be referring to with that. I camp in spots that others would drive by (usually because I didn't make reservations and end up with spots that others wouldn't take...) and have been in some pretty unlevel situations and never had an issue.
    I have had no issues with my hitch and would buy one again. But I know that i would fail to slide a manual hitch on a dark rainy night after driving for 14 hours, so I went for the safe bet.
    However, in your situation I would wonder if you'd be better off with a fixed hitch and a revolution pin box? I don't know much about them, but in principle should accomplish the same result as a slider hitch without extra weight for you to deal with. I am sure that someone else here would know more about that one.
  • i pull with an F250 crew with the same bed. I don't need a slider.
    When not in use and the fifth wheel is in the barn the hitch hangs on the king pin.
    I am an old pfart and do not lug my hitch in and out of the truck.
  • Kevin, you may not need a sliding hitch. I have not needed one with last two FWs, and two 6' 9" Fords.
    Jerry
