Cummins12V98
Dec 31, 2019Explorer III
Thermoguy wrote:
For those of you using a temp gun. What are you looking for? What is a normal temp? Are you looking at the tire, the brake drum or something else?
I would imagine the temp of the road surface of the tire is much different than the sidewall. Just curious, I have a temp gun that shows a picture, but I have never used it on one of my tires when on a trip.
thanks
I hit the center or the tire along with the hub. Tires should all be similar temp. There will be variables. Rear tire on tandem axles will run warmer. Road shoulder being lower may cause that side to be warmer. Sun hitting may be warmer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
