laknox
Jan 02, 2020Nomad
Me Again wrote:
Rear trailer tires will run slightly warmer than fronts that get direct air flow. Driving East of West the sunny side tires will be warmer that the shaded side. However a strong wind against the sunny side can make the shaded side tires carry more load and be warmer. I saw this for Phoenix to Palm Springs with 40 MPH wind out of the South on the 6 hour run.
Fold up stairs right in front of the door side tires can cause them to run slightly warmer.
FWIW, sunny side tires on both my FWs tended to run 10-15 hotter than shaded side. Same on my truck. When towing out here in the SW, in the summer, load charts are out the window. I want them to full cold psi to help dissipate the heat. I've seen nearly 150 on the sunny side tires towing across I-8 to San Diego. My old Komfort, with 860 lbs more GVW than my KZ, would always run in the 140's after 1-2 hours. E tires at 80 psi, 60-65 mph.
Lyle
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
