- Cummins12V98Explorer III
larry barnhart wrote:
My thoughts about china made tires are this. Bought a new 2018 car with China tires and traded them in before 500 miles.
chevman
My NEXEN's went byby at 250 miles and replaced with Michelin MS2's. - Colbee55Explorer
CALandLIN wrote:
Colbee55 wrote:
What kind of tires for the 5th wheel seem to hold up the best?
Looks to me like you’re refitting an older trailer with new tires. A lot has happened in the tire industry since your trailer was fitted with it’s original tire & wheel assemblies. Probably the best thing to do is a complete assembly change for all wheel positions.
Any of the ST225/75R15 LRE tires will provide the load capacity you seek. There are numerous manufacturers to chose from with GY being the only USA manufacturer and they will be the most expensive.
However, there is a new all steel 15” trailer tire available. Greenball is providing them and their brand name is Tow Master. They are ST225/75R15 LRF.
Click Here!
Thanx, will check them out. - CALandLINExplorer
Click Here! Cummins12V98 wrote:
Mine calls for 50 psi and I run them at 65. No center wear, stops just fine, rides better than ever.
Over inflation will cause center tire wear, less stopping ability and worse ride.
Same with my truck I run them 10 to 20 more than the door sticker with same results.- larry_barnhartExplorerMy thoughts about china made tires are this. Bought a new 2018 car with China tires and traded them in before 500 miles.
chevman - Cummins12V98Explorer III
time2roll wrote:
80 psi for max load rating. Why not 80 psi? Put them on and air them up. I bet they ride better than ever.
Well I asked you why since you posted about a 80psi tire and you answered with a why???
I can tell you why NOT go MAX when coming from a lower load range tire. It's because the other tire DID carry the load at it's MAX rating as most RV's are loaded to the tires MAX. Now since it was fine at 65 it would most likely be the same psi for the "E" to carry the same load.
PER GY Tech Support "When up sizing in load range weigh the tires compare to the load/inflation chart and add 5psi. - neil57ExplorerI have a 2year old ser of road rider 225/75/15 E ST tires, one is egg shaped. Not a fan of these tires at all, am switching to 16”LT tires. Will give you a deal on the set mounted on aluminum rims LOL.
- Colbee55Explorer
xtech wrote:
Hello, I am a fellow Albertan. Just put my third set of Road Rider ST tires on. Have had no problem and tow many miles, down to Arizona in winter and around Canada summer. Road Riders are from China but are recommended over even the new made in USA goodyear. Go to fountain Tire, they handle them. They come in your size in Load Range D or E. I just put on 4 E range, $119.00 Canadian each. D range good for approx. 2500 lbs each and E for 2800 each so D would work for you. Talk to Fountain Tire they sell lots and recommend them.
Sounds good. Thank you. I will definitely pass this on to my husband. - xtechExplorerHello, I am a fellow Albertan. Just put my third set of Road Rider ST tires on. Have had no problem and tow many miles, down to Arizona in winter and around Canada summer. Road Riders are from China but are recommended over even the new made in USA goodyear. Go to fountain Tire, they handle them. They come in your size in Load Range D or E. I just put on 4 E range, $119.00 Canadian each. D range good for approx. 2500 lbs each and E for 2800 each so D would work for you. Talk to Fountain Tire they sell lots and recommend them.
- Me_AgainExplorer III
An over inflated tire for the load is subject to more of a chance of impact damage and have a reduced contact patch, thus reduced braking ability. A message I received from a Michelin CS rep. Chris
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
