MFL
Oct 04, 2020Nomad II
As others mentioned, if 8K is advertised wt, it is going to be a load that may take you over some ratings. The newer aluminum 150s have a higher RAWR. It is possible to tow that trailer, with certain F150s, even if 8K is the dry wt. Yes, you have plenty of towing power, no issue there. Using E-rated tires, and maybe air bags will help.
The short answer is, YES, it is possible, and I see it done often in my area.
Jerry
Jerry
About Fifth Wheel Group
