Second_Chance
May 28, 2017Explorer II
Forget max towing capacity. With a single rear wheel truck (which I assume from your 3,320 lbs. payload capacity), you will reach the rear axle capacity long before you max out on towing capacity. Use 25% of the trailer's GVWR to estimate loaded pin weight. If that number is more than what you have left for rear axle capacity (don't forget the weight of the hitch, too), it's too much trailer/not enough truck. A 16K fifth wheel will put about 4,000 lbs. on the pin when loaded - too much for a single rear wheel truck.
Rob
Rob
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
