jarobinson1000's avatar
Jul 30, 2013
TRUCK TOWING CAPACITY
I am considering purchasing a 5th wheeler in the next couple of years and I am trying to decide which pick-up truck will work for me. Here are the particulars of the trailer (all weights in pounds):
Forest River Cedar Creek 38RE
GVWR 16540
Unloaded Vehicle Weight 12920
Cargo Carrying Capacity 3620
Dry Hitch Weight 2540
Loaded Hitch Weight 3251
I decided to look at only Dodge RAM trucks for now but I would think that most truck manufacturers would have similar capacities.
RAM 1500
I knew that the RAM 1500 would be too small but let's start there:
2013 RAM 1500, Quad Cab RAMBOX, 4x4, Laramie, 6'4" Box, 5.7L Hemi V8 Gas, 6S Auto Transmission
GVWR 6800
Base Weight 5609
Front Axle 3196
Rear Axle 2414
Payload Capacity 1191
GAWR (Front) 3900
GAWR (Rear) 3900
GCWR 15650
Maximum Trailer Weight 9850
I assumed that the truck would be loaded with 2 "standard" passengers at 154 lbs each (although they seem very light) plus 233 lbs of cargo for a total loaded weight for the truck of 6150 lbs.
The first problem is that the loaded weight of the truck (6150 lbs) plus the loaded hitch weight of the trailer (3251 lbs) totals 9401 lbs which exceeds the truck GVWR of 6800 lbs by almost 2600 lbs.
The second problem is that the truck rear axle load (2414 lbs) plus the loaded hitch weight of the trailer (3251 lbs) totals 5665 lbs which exceeds the truck rear GAWR of 3900 lbs by 1765 lbs.
The RAM 1500 is clearly not enough truck.
RAM 2500
Surely the RAM 2500 would be enough:
2013 RAM 2500, Mega Cab RAMBOX, 4x4, Longhorn, 6.7L Diesel V6, 6S Auto Transmission
GVWR 10000
Base Weight 7983
Front Axle 4778
Rear Axle 3205
Payload Capacity 2017
GAWR (Front) 5500
GAWR (Rear) 6200
GCWR 25000
Maximum Trailer Weight 16850
Again, I assumed that the truck would be loaded with 2 "standard" passengers at 154 lbs each plus 234 lbs of cargo for a total loaded weight for the truck of 8525 lbs.
Again, the first problem is that the loaded weight of the truck (8525 lbs) plus the loaded hitch weight of the trailer (3251 lbs) totals 11776 lbs which exceeds the truck GVWR of 10000 lbs by 1776 lbs.
And again, the second problem is that the truck rear axle load (3205 lbs) plus the loaded hitch weight of the trailer (3251) totals 6456 lbs which exceeds the truck rear GAWR of 6200 lbs by 256 lbs.
This is closer but it would seem that even the RAM 2500 is not enough truck.
RAM 3500
Wow, do I really need to go this big!
2013 RAM 3500, Mega Cab RAMBOX, 4x4, Longhorn SRW, 6.7L Diesel V6, 6S Auto Transmission
GVWR 12400
Base Weight 8258
Front Axle 4972
Rear Axle 3287
Payload Capacity 4142
GAWR (Front) 6000
GAWR (Rear) 7000
GCWR 25000
Maximum Trailer Weight 16570
Again, I assumed that the truck would be loaded with 2 "standard" passengers at 154 lbs each plus 234 lbs of cargo for a total loaded weight for the truck of 8800 lbs.
So, the loaded weight of the truck (8800 lbs) plus the loaded hitch weight of the trailer (3251) totals 12051 lbs which is just shy of the truck GVWR of 12400 lbs by about 350 lbs. Yeah!
Next, the truck rear axle load (3287 lbs) plus the loaded hitch weight of the trailer (3251) totals 6538 lbs which is just shy of the truck rear GAWR of 7000 lbs by 462 lbs. Again, yeah!
Finally! the RAM 3500 seems to be the "smallest" Dodge RAM that would not be overloaded.
Am I being too conservative? My colleagues at work all tell me I am being WAY too conservative, that even the 1/2 ton RAM 1500 would pull this 5th wheeler but "for sure" the 3/4 ton RAM 2500 would. The only thing they say I would be gaining by buying the RAM 3500 is a lighter wallet and more trips to the diesel pumps.
Any sage advice out there?
