Alex_and_Tee's avatar
Alex_and_Tee
Towing Capacity
I am going to re-visit this subject with a little more specificity to my situation. I ordered back in March a 2022 Tiffin Allegro Open Road 36LA with the new to this year liquid spring option. This was before the new brochure and specs were posted and right at the beginning of the take over by Thor.
Regarding my towing capacity, I am a bit confused. The brochure for the 36LA with liquid spring option shows a hitch rating of 5000 lbs. and a max trailer weight of 6000 lbs. On the surface, this doesn’t make sense.
To further confuse things the GVWR is 26,000 lbs. and the GCWR is 30,000 lbs. according to the brochure. This is a difference of 4000 lbs. So, what weight can I actually tow? 4000, 5000 or 6000 lbs.??
By everything I’ve read, I think I am limited to 4000 lbs. If that’s the case I’m kinda screwed because my new Bronco Sport is 3500 lbs. and the aluminum trailer is 1100 lbs. FWIW the non liquid spring version has a 6000 lb. spread between GVWR and GCWR. I may have sacrificed towing capacity for ride/handling quality.
