cruising_spud's avatar
cruising_spud
Explorer II
Jul 25, 2013
Fifth Wheel Weight and a Truck
We currently have a Class C but have started thinking about a fifth wheel as a possibility for our next rv.
My question is about fifth wheels and trucks needed to pull them.
I am looking at two different fifth wheels.
One has: a maximum GVWR of 15,000
a base weight of 11,600
a hitch weight of 2,500
This fifth wheel measures 29'5"
The other has: a maximum GVWR of 17,500
a base weight of either (there are three models)
12,600 and 12,280 and 11,900
a hitch weight of 2,690 and 2,570 and 2,560
These fifth wheels measure 32'11"
My question is-what size truck would we need to pull these fifth wheels?
Thank you for your input.
  • Why does everybody want a XXX Ford ? Makes no sense to me to look at IMHO the weakest of the three. Heck Dodge has upped the any to 30,000 pounds now. Far more than Ford or GM
  • You need a truck rated to tow the 5th wheel trailer weights and with a payload capacity to handle the hitch pin weight you listed and stuff you are going to take with you. LOOK at the truck specs from the manufacturer and pick one. Don't rely on personal opinions, you are legally responsible for having an adequate tow vehicle.
  • We are looking at similar rigs and we are looking at a one ton F350 diesel dually.
  • 350/3500 1 ton full size dually for any of those
    And forget about them published hitch weights (pin weight) as they are 'dry' numbers and will increase when rig is loaded up ready to go camping.
    Using 20% of GVWR will get you closer to actual camping ready pin weight
    Trucks cargo capacity/payload capacity is what gets eaten up fastest.
    And with those GVWR numbers you are into dually territory
