laknox
Jul 24, 2014Nomad
Jerry_L wrote:
We're new to the RVing world and are planning on a trip to a National Park that has no water hookups. Traveling with 40 gals of water for 300 miles bad for 5th wheel trailer and truck. I have a 3500 HD, one ton Silverado. Thanks for your input. Jerry_L - SLC
Thanks to all those to replied. I was being told by 5th wheel owners in SLC, Ut., not to travel with the fresh water tanks filled. I always thought that was weird advise. I feel better knowing my idea of leaving home with a full water tank is not "weird".
Personally, I travel with a minimum of water on the road, maybe 10 gallons. We do a family boondocker every year up in the mountains. Why carry an extra 350 lbs up several thousand vertical feet if I don't have to. I've got a spot about 30 miles from our camp where I can water down, including 2 7 gal jerry cans. Costs me $5 and the water is =much= better tasting than our city water, even if we only brush our teeth with it. :-) If I know I'm going to an area with a water hookup, then no need to carry water; if I'm not sure, then I'll carry more than I usually do, but not a full load. Again, that's the way I do it; YMMV...
As others have said, having a full tank can help with ride, especially if you're otherwise traveling light. Also, if you know you're going to be running through windy conditions, especially crosswinds, having a bit of weight in =all= your tanks, helps to lower the CG of your FW for stability. That, and running slower.
Lyle
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
