- insp1505Explorer
jjjandrbaker wrote:
That, I did not know! Thanks for the tip. I always thought the more pressure, the faster it was filled. Yikes! I've been lucky.
Up to a certain point that is true but the system has to be able to vent as fast as it fills.
The tendancy is to stuff the end of the hose in the hole and walk away to do something else while the tank fills as some of the large tanks can take a long time. By doing this you are only allowing the much smaller vent tube along the side of the larger main tube to vent off the air because you essentially cut off any venting action of the fill tube with the end of the hose stuffed in it. On some systems the vent tube cannot keep up and the tank begins to pressurize, that's when running full blast can be an issue. Also if you walk away and don't notice when it becomes full and if the hose becomes lodged in the fill spout the hydraulic pressure of the incoming water will swell the tank as now the vent can't dispell the water as fast as it is being forced in.
On the other hand if you stand there and hold the hose with an air gap between the fill spout and the end of the hose you usually can run it in at a much higher rate without problems because the end of the hose isn't trapping any venting air coming out of the fill tube and you're there to shut it down when it is full.
The walk away method is the one where you have to be very careful and not run too high of pressure. - deleted-2Explorer
ScottG wrote:
Same here!
It's full when my shoes get wet.
Should have posted a pic from today's tank filling regiment :)
I got the shoes wet too. - jjjandrbakerExplorer
insp1505 wrote:
X7
Don't run it full blast either. Slower is better as the tank has to vent out the air that is being displaced by the water. If you run it in too fast the tank will expand like a balloon until it bursts or breaks the floor joists or straps that hold it in place. Expensive repairs you don't want to deal with that is easily avoided by slowly adding water.
That, I did not know! Thanks for the tip. I always thought the more pressure, the faster it was filled. Yikes! I've been lucky. - insp1505ExplorerX7
Don't run it full blast either. Slower is better as the tank has to vent out the air that is being displaced by the water. If you run it in too fast the tank will expand like a balloon until it bursts or breaks the floor joists or straps that hold it in place. Expensive repairs you don't want to deal with that is easily avoided by slowly adding water. - GoostoffExplorerMine has an overflow hose/vent that just shoots out of the bottom of the trailer. Our old Hornet had the vent right where the fill pipe was at. When the water backed up it was full.
- pianotunaNomad III
jjjandrbaker wrote:
In my case, once the tank is full, the water starts pouring out the intake telling me to turn off the hose.
X6 - ScottGNomadSame here!
It's full when my shoes get wet. - bpoundsNomad+1. Full when no more goes in. Gauge is worthless.
- sandtshermanExplorer
X2 - jjjandrbakerExplorerIn my case, once the tank is full, the water starts pouring out the intake telling me to turn off the hose.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
